I had considered the Bassman combo I built this summer to be finished, but every once in a while it would make a crackling noise on certain chords or notes, or when thumped. I'd take it out of the cab, put it on the bench and could not recreate it, so I'd put it back together and it would be fine for a while. Then, I'd pull it out for some perspective customer, and it would do it again. Quite frustrating and embarrassing. I left it apart for a couple of months until today. This time I was able to find that if I rotated the power tubes just a certain way, I could get the noise. This was on both tubes and both sockets. I figured it had to be a bad connection, (even though I am very meticulous) so I reflowed all the socket connections, but no change. Then I tried another set of tubes, same type NOS GT6L6B (really Sovtek 5881WXT), and now I couldn't get the noise while moving the tubes.
So now I figure it must somehow be the tubes, but I can see nothing obvious. I put them in my pan-vise and reflowed all the pins, and now the problem is gone. So it would appear, as long as the noise never returns, that there were dodgy connections at the pin(s) of both tubes. What are the odds on that I wonder? They are a matched set, so they must have been made on the same machine on the same day I suppose? Anyhow, I feel better that the problem wasn't because of something I did poorly, knock on wood.
