I recently acquired a 1970's Bassman Ten to use for a Fender Rhodes....But the amp isn't working properly..The seller said in the auction that it was working fine. When it arrived it had very very little output. Had the amp turned up all the way...and it was dead quiet. I could hear my picking but it was very faint. I tried all the channels and it was the same thing. I tried different tubes, and it was the same thing. I didn't get to try "New" tubes but I tried tubes that I knew worked for sure, and got nothing. If anyone could help me with this it would be greatly appreciated. Someone told me it might be bad Capacitors, or some kind of resistor failure. But Would like to hear a little more on the situation. Thanks.
Vintage Fender Bassman Ten......Little Output problem
Originally posted by andypena View PostI recently acquired a 1970's Bassman Ten to use for a Fender Rhodes....But the amp isn't working properly..The seller said in the auction that it was working fine. When it arrived it had very very little output. Had the amp turned up all the way...and it was dead quiet. I could hear my picking but it was very faint. I tried all the channels and it was the same thing. I tried different tubes, and it was the same thing. I didn't get to try "New" tubes but I tried tubes that I knew worked for sure, and got nothing. If anyone could help me with this it would be greatly appreciated. Someone told me it might be bad Capacitors, or some kind of resistor failure. But Would like to hear a little more on the situation. Thanks.
