I found that there are 2 methods of biasing this unit, both currently on the web and similar but not the same. The one titled "Nomad Bias" is measuring (and adjusting) for 75ma at the standby switch but the other, titled "Vintage Series Bias" is a plate dissapation method. I found that in order to get the recommended 70% of max el84 plate dissapation that I had to raise the current at the standby switch to approx 92ma.
Is there actually a difference between the Vintage series or is one of the above bias methods incorrect?
