Unfortunately I can't measure more than 375V anywhere on the tubes - might be diodes failed in power section?
Hiwatt 200 (DR201) bias pot + general questions
I think everything's OK:
I may confused PIN2 and PIN3 with PIN3 and PIN4 because they are written between the pins, not "at the pin".
But there's another case. I was told this amp is CLASS B amp. Could not find any information how I should bias Class B amp? Is the calculation the same as AB? At the moment tubes have got like 18-20mA each. Form the 70% safe plate dissipation rule, with 680v it would be 25mA... so 18 is a bit cold? But it may be Class B that is set differently?
We still don't know your actual screen and plate voltages.
The TFK EL34 datasheet recommends for what they call "Class B" 30mA@ Vp=500V/Vg2=400V and 25mA@ Vp=800V/Vg2=400V. If you measure cathode current, add 4mA for screen current.- Own Opinions Only -
