The noise goes up and down with volume and is in both the clean & soak channel. The tubes are new and tested good. Would the problem be a resistor at the preamp or the power amp stage? Would it most likely be a bad cathode or plate resistor?
Carvin Nomad 112 Crackling and Hissing
Is the earthing from the wall to the mains cable correct
Does exist noise when the guitar is plugged into the amplifier:
- when the volume on the guitar is at max (10)
- when the volume on the guitar is at min (0)
Check for cold solder joints on G1 (ferrite bead), R1, J1 (input jack) 1)It's All Over Now
Originally posted by vintagekiki View PostIs the earthing from the wall to the mains cable correct ......
Does exist noise when the guitar is plugged into the amplifier:........................................
- when the volume on the guitar is at max (10) ........................................................ ......
- when the volume on the guitar is at min (0)..................................................... .............
Mains ground is fine. Noise is ONLY present when jack is plugged in. Noise increases and decreases with either guitar or amp volume. When I pull the jack out, it's dead quiet. I resoldered J1, G1 and R1. Noise still present.
5 minutes later I turned it back on and no noise. I'm baffled, help!
A fault like that would not turn up on a tester, and is not unheard of for new tubes. Was the problem already there before you put the new tubes in?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostA fault like that would not turn up on a tester, and is not unheard of for new tubes. Was the problem already there before you put the new tubes in?
I've had several new tubes right out of the box that caused problems. Including problems like your having. Another thing might be dirty contacts. Tube pin socket holes, jack contacts and any non solder connection. That amp isn't a spring chicken It might be time for some Cramolin.Last edited by Chuck H; 10-21-2019, 04:53 AM."Take two placebos, works twice as well." Enzo
New is not the same thing as good. Quite a while ago I bought a box of 100 new 12AT7 GE tubes. EVERY SINGLE ONE of them, for the first minute or so of power up would crackle and make noise, and then they were quiet and fine, never to bother us again. I used them until they were gone, never had any issues other than their first moment of life. So tubes with problems can wind up good. Point being, never take tubes for granted.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostNew is not the same thing as good. Quite a while ago I bought a box of 100 new 12AT7 GE tubes. EVERY SINGLE ONE of them, for the first minute or so of power up would crackle and make noise, and then they were quiet and fine, never to bother us again. I used them until they were gone, never had any issues other than their first moment of life. So tubes with problems can wind up good. Point being, never take tubes for granted.
Originally posted by Chuck H View PostAnother thing might be dirty contacts. Tube pin socket holes, jack contacts and any non solder connection. That amp isn't a spring chicken It might be time for some Cramolin."Take two placebos, works twice as well." Enzo
Originally posted by Perkinsman View PostI’ll clean the contacts today. Is there a way to test the “barrel” type jack or the ferrite bead?
Ideally you would test the jack & bead by grounding the signal right after it. You may need to ground with a cap if there is DC present at the point you are grounding. If it makes the noise disappear, then you have isolated the problem to the jack, bead, or their connections.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostCan you post the schematic?
http://i1282.photobucket.com/albums/a527/tamedragon66/Nomad_6_zps2d17ce5c.jpg
Carvin Nomad 112 chassis 1)It's All Over Now
Great. You can directly ground the tube side of the ferrite bead. Does the problem remain or disappear?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
The "barrel type jack" (Cliff jack) is as easy to test as it is to see what it's doing with it's contacts. Just look at it to determine when as where it should contact with and without a jack plugged in and use your meter to check continuity.
I'm not experienced with this, but what could go wrong with a ferrite bead? It's ferrite and it doesn't connect directly/conductively to anything. The way I figure it, it's either there or it's not. If it's there then it's doing what a ferrite bead does. Unless they can become somehow polarized or otherwise incorrectly "charged" or something.?."Take two placebos, works twice as well." Enzo
