Thanks a lot guys for all the info I read here and learned, I'm just in the beginning of the game...
I've been collecting Ampegs for years and some time ago started to make simple adjustments like adding bias pots, caps change, do grounding etc.
Now, I have a question about 1961 B15N - It's cathode biased amp. It's ~63mA a good value for bias on this model? I checked 250r bias resistor and it's up to specs. Isn't it a bit high? I know that cathode biased amps have more bias, but still, this looks high.
Another one is for B15NF (1970s). The amp sounded great but have some suspicious caps and it was not grounded so in the summer, I have changed 3 prong cable, bias cap, and 30uf/600V cap too + new standby switch and fuse holder. I have just tunred it on, checked bias on the probe and turned off (no sound test). After few months I turned it on and tried to play something but sound is barerly hearable super low level and distorted. Tubes glow blue when I hit the strings. Bias changes, right B+ is on the tubes too. What could be wrong? Pics
PRE![Click image for larger version
POST
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
PRE
POST
