Marshall DSL100HR garbled output
  • Marshall DSL100HR garbled output
    Having no luck with fixing the output of this amp. I’ve narrowed it down to a preamp issue.
    Both channels feed through
    V2:
    Pin 1: 297.2vdc
    Pin 2: 1mvdc
    Pin 3: 2.9vdc
    Pin 6: 262.1vdc
    Pin 7: 1mvdc
    Pin 8: 2.1vdc
    V3
    Pin 1: 227.2 vdc
    Pin 2: 0.7mvdc
    Pin 3: 1.4vdc
    PI plates are at 294vdc(pin 1) and 287vdc(pin 6), grid to cathode is -1.4 between pin 2/3 and 7/8. Power tubes are biased to spec. Don’t know where to go from here.
    V2:
    Pin 1: 297.2vdc
    Pin 2: 1mvdc
    Pin 3: 2.9vdc
    Pin 6: 262.1vdc
    Pin 7: 1mvdc
    Pin 8: 2.1vdc
    V3
    Pin 1: 227.2 vdc
    Pin 2: 0.7mvdc
    Pin 3: 1.4vdc
    Did you ever get a scope? If you did not I can probably get you an older one for about $40. I'm in Pace an also have a scope cart for nick so I'm sure I'll be in Pcola soon.
    So the amp is ok when you feed in through the FX loop?
    Thanks,
    nosaj
