Found this document from the University of Colorado (Posted on the University of Tennessee website ) while looking at some data on capacitor discharging and wanted to share!
High Voltage Safety Manual.pdf
An interesting safety annecdote: I'm pretty diligent about discharging the HV caps when performing any service on an amplifier. Years ago, I built a discharge tool out of a set of heavy duty insulated clip leads I found in a box of TV repair equipment. It's been a reliable tool for years, and about a week and a half ago I went to use it like I normally do and happened to test the DC voltage on the caps to make sure that the voltage is bled off. I have to admit, I don't always do that. This particular time, however, I did, and read a high voltage still present in the caps! Sometimes it's a tight fit, so I thought the clips hadn't made good contact and I reattached the discharging leads. But I monitored the voltage on my DM, and the cap was not discharging. The current limiting resistor, had gone open with no visual indication of any heat damage or anything.
I'm glad I took the extra 10-15 seconds and read the DC voltage. May have saved my life this this time. Definitely saved me further injury by indicating that a device I depend on for safety had become faulty and needed to be replaced or repaired.
Here is a redundant copy of the above doc as well:
High_Voltage_Safety_Manual.pdf
