Hi all, This weekend I worked on a HRD that had alot of crackle/sizzle. I fixed it by resoldering the PI pins and the amp sounded good but because one of the filter caps was visually leaking, I replaced all 6 main caps. Brought up the amp slowly on the variac (equipped with a volt & current meter). Everything was fine, it sounded good after that point too. Then for some unknown reason I decided to replace a small cap that happened to be in my line of sight at the moment, C38, 22uf 63v. One leg of the trace happened to lift and I repaired carefully with a hardwire from one end to the other. I soldered in a new cap in and plugged into the variac. I brought it up slowly and the current started rising too quickly so I shut it down. Since it was the last thing I had done prior to the current rise problem, I assumed it's the trace repair...... but it showed continuity for the repair so I reflowed all the cap solder joints for the new caps I had installed and still no improvement. Any suggestions how to troubleshoot this since I can't power up past 60vac without the current jumping past 2A?
HR Deville Runway Current Problem
Your new trace showed continuity for its original path, but perhaps it has gained continuity to some other adjacent trace where it ought not be?
C38 is the filter cap for the bias supply. That is a NEGATIVE supply, so any chance you soldered it in backwards? The POSITIVE end is grounded, not the negative.
Ah geez, I had ya beat, but got caught up in Ferris Bueller singing Beatles tunes.Education is what you're left with after you have forgotten what you have learned.
OK, well check the neg end for resistance to ground. Is it shorted to ground somehow? I had a guy once bring me a unit he had recapped. He forgot to trim the excess lead wires off one of the ccaps, and they stuck against the metal chassis, shorting out his HV line. No it wasn't me, but I have done bonehead things too.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostOK, well check the neg end for resistance to ground. Is it shorted to ground somehow? I had a guy once bring me a unit he had recapped. He forgot to trim the excess lead wires off one of the ccaps, and they stuck against the metal chassis, shorting out his HV line. No it wasn't me, but I have done bonehead things too.
As I stated, it ran fine after recapping (I pigtailed). The runaway current problem started after I replaced C38 & had to hardwire patch one side due to a lifted trace.
As recommended, I pulled the power tubes & as a result, now there is no runaway current.
You bypassed my question. I do not doubt you connected the cap to the resistors correctly. But I asked if that connection was ALSO shorted to ground.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostYou bypassed my question. I do not doubt you connected the cap to the resistors correctly. But I asked if that connection was ALSO shorted to ground.
Originally posted by Perkinsman View Post......Testing with continuity shows no shorts between the positive side and ground. What have I missed?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by The Dude View PostThe positive side of the cap SHOULD be ground, so something is wrong. IMO, you also need to add some solder to your connections. They don't appear to be soldered very well.Last edited by Perkinsman; 11-21-2019, 12:10 AM.
Originally posted by Perkinsman View PostYes, the positive side has continuity with ground. The negative side has continuity with the 2 resistors. There are no shorts between each of those connections. I added some solder to the joints in question. I put the power tubes back in and the current started rising so I quickly tested the bias voltage at TP30 and read 175mV, 3x over the setting I had set at 62mV. I then started lowering the bias back to 60mV and the current stabilized. I'm starting to think that the bias pot is not working properly. Is there a way to test it?Logic is an organized way of going wrong with confidence
I can see the cap has no excess wires, what I meant was, get out the ohm meter and with power off, MEASURE resistance to ground from the supply line to ground. Across C38, does it measure shorted or low resistance? Don't pull the cap, I am not expecting the cap itself to be shorted, just something in teh circuit.Education is what you're left with after you have forgotten what you have learned.
Originally posted by nevetslab View PostYES. Remove the power tubes again, then measure the range of negative bias voltage from min to max on the bias pot. Note the bias voltage where you have it set that gave you 62mV at TP30. Using the resistor values in the bias network, I calculate the adjustment range is from -68.8V thru -55V. I'd expect you can go lower than -55V, which would increase plate current.Last edited by Perkinsman; 11-21-2019, 01:22 AM.
