Hi Folks,
Have just registed!!
Yesterday I arrived at my weekly GIG, took the amp from its box (Yes I still have the original box with all the styrofoam corners), set it in a chair in the stage, power it up and waited it warm a little while my band mates were doing the same with their gears.
Then we started the soundcheck, and as soon as I turned the stand by switch on, I heard a strange noise coming from the amp. Something "like" an egg being fried.. shhhhhfrrrshhhhhfrrrrr. I could even play the amp since the noise was not that loud, but as soon as I stopped playing there it was.... Then I plugged the guitar off and started investigating... The noise is there as soon as the stand by switch is flipped. It happens in both normal and drive channel (even in the more drive). Turning the reverb knob down also doesn't help. Rotated all the knobs and nothing helped.
So I took the back cover and pulled all the tubes, reinserting them firmly hoping that a bad contact would be the cause of the problem. Nothing happened it is still there...
Later at home I swapped v1 with v3 and after that v3 with v2 with no results what leads me to think that a bad pre amp tube wouldn't be an issue. The tube sockets seems to be tight enough.
Just ordered a full retube kit from Eurotubes hoping that this will fix the problem.
I would appreciate any inputs that I should look for before sending the amp to a technician. I hope that this could be something easy to fix like for instance dirt in the sockets or something like this.
Thanks in advance,
Thanks in advance,
