Loud Tone From Speaker
  • Loud Tone From Speaker
    Im having an issue with a solid state amplifier. When i plug the amp in and turn the speaker on, i get a loud tone coming out from the speaker. The diaphragm of the speaker also moves back and just stays there. Whats causing this?
    You have a problem with the output of the amplifier and it is sending DC voltage to the speaker. It will burn up the speaker pretty quickly if given a chance.
      That would most likely be DC on the speaker. Probably from a shorted output transistor or a ground fault. You should not try to operate the amp through that speaker again before it's fixed or you stand a good chance of roasting the speaker.
        The noise is usually caused by the fault placing an excessive load on the power supply, This overcomes the ability of the smoothing capacitors to maintain a steady DC supply and the ripple is heard through the speaker as a loud buzz.
          TURN IT OFF you will destroy the speaker. Your power amp is "blown". Meaning something is very wrong.
