Good day to everybody...I have this one here and after going through the circuit, I have audio up to the relay.....the relay is not being activated so the audio is not being fed to the speaker....the relay is controlled by a power transistor which checks out fine.....thee is 14V on the tab so the transistor is not being turned on?? traced back to the other transistors and low value resistors and everything checks out fine....diode checking the transistor junctions also checked out fine....I did find a capacitor with a relatively high esr and replaced that but same thing.....powers up no sound....Line out/ Send works fine.....signal is available at the relay but won't switch.....I will post the schematics for viewing....
Cheers
Cheers
