I have a Roland Super Cube 100 (not bass version) with an power indicator LED that isn't lighting up. The circuit is foreign to me and is different than what you see in the schematic for the bass version. I'm uploading images of the bass version schematic and my own sketch of the circuit in question including voltages. All the surrounding components that are pictured check out as in spec on the DMM. In my experience these small red LEDs typically run with around a 2V voltage drop and I tested this one outside of the amp and it checked out as such and lit up normally. I tried adding different values of resistance at different points in the circuit to try and adjust the voltages on either side of the LED hoping that if I could modify it so that the voltage drop across the LED was in the 2V neighborhood it would work as it did in my experiment outside of the amp. But any change in voltage was negligible with the resistors I tried (e.g. 1K, 100K) and the voltage drop on the LED remained the same.
I need guidance please!
..and thanks,
- B
..and thanks,
- B
