Hi all,
I'm having some problems with the amp in title.
Came in with a blown mains 3.15A fuse. Tested it with a lightbulb limiter, it indicated a short. Narrowed it down to one of the main filter caps, after removing it LBL doesn't glow bright anymore.
Next thing I did was insert tubes in it, but limiter still glowed a bit more than normal. As you may know, this amp has around 32VDC heater supply, distributed on 4 power amp tubes in series with PI tube, from which 6VDC supply goes to V1 and V2 in parallel.
The amp does not blow fuses anymore with all tubes in, but I'm getting 5VDC across 4x 6L6 tubes, which leaves 12VDC for PI, V1 and V2, which causes preamp tubes to glow really bright. I didn't leave it on for more than 5-10 seconds at a time while taking measurements.
Anyone seen something like this on these amps?
It's a PITA to remove this board as V1 and V2 sockets are soldered to the board, so I'd like to address as many issues as I can when I do remove it again.
When I do remove one power tube for example, LBL stays dim, so I suppose +14VDC relay supply is fine and not causing short?
peavey_valveking_100_212.pdf
