Hello All,
I live in the UK [so its 240v 50Hz A/C mains voltage] and I have an old Peavey 400B/G Mk. III Series Amp. that belongs to my son-in-law [who plays keyboard] and he desperately hopes that I can get it working again.
I also have a Circuit Schematic [us Brits call em Circuit Diagrams] for this Amp. due to some kind person posting it in Maintenance,Troubleshooting & Repair on this good forum. A big thank you for that .
I come from a UK TV/CTV repair background from 1964-2000, then I was recruited to UK MoD, Hereford for 12 years and retired from there in 2012.
At first the amp. was just blowing 4Amp mains input fuses at switch on so I isolated the Output Modules by unplugging both their power supply molex plugs. This stopped the 4Amp mains input fuse blowing so I then Fluke DMM checked all the supply rails for good measure. All seemed well with the +52v,-52v,+15v and -15v although I haven't had chance to scope them for any sign of ripple yet.
So I then removed all the Power Output Transistors firstly from the left module and found that Q4,Q5,Q6 had gone short along with O/C emitter 10W W/W resistors R29,R30,R31. I checked Q13,Q14,Q15,Q16 with my DMM and they all seem OK.
So here are my Questions if you would be so kind:
1. Can I safely run this Amp. without any load / Loudspeaker?
2. Can this be a Driver or pre-driver issue leading to this high current draw or is it simply failure of O/P Transistors?
3. Is this likely to be down to the specially selected PV diode array [CR14] 13886 failing or perhaps something else?
I am familiar with putting a 60W light bulb in series with the mains input to limit current flow.
Sorry for this long post and all the questions but I am hoping someone can provide help and guidance !!
Regards,
Mike
Peavey Mark III Bass + PA Circuit Schematic.pdf
Regards,
Mike
