No output from either channel in Fender Blackface amp
  • No output from either channel in Fender Blackface amp
    I did a full electrolytic re-cap on a 1965 Pro Reverb. When I powered it up, I had very, very little sound from an iPod. I thought PI tube? Nope it makes noise when I put meter to grids. Moving back to V1 and V2, I had 450v on the plates, 9/10 volts on the cathodes, and we know that's not right. I had signal on the grids, but nothing on the plates, but they did also make noise when I put meter to plates, so I know from that point forward is working. Eventually I found the rightmost ground wire that the first cathodes from V1 and V2 share was broken under the board. So no signal getting past the first triode in either channel. I fixed this and all is well. Another 65 Pro Reverb lives on.
    Thought I would archive this for future reference.
    I was surprised by the title of this thread because I didn't know you were posting a story with a solution. I didn't think YOU would have failed to find the answer to something like this. Glad to see your troubleshooting intact Always glad for the guys that service those old amps and I hope it went about as fast as writing it and you made some $$$.
      Good job Randall and thanks for posting in the way that you did showing steps to figuring out issue May it help some other tech.
      nosaj
