Recent purchase, his complaint appears to have low output, not much gain and a bit of hum.
Looks like it spent a lot of time in a dirty damp basement. Faceplate has a lot of surface rust, reverb supports rusty and the inside where the pots are looks like the inside of a desktop computer that hasn't been cleaned in 10 years.
Took a look and checked a few things after cleaning it. Almost every resistor was out buy 30 to 40% and a bad cap on the reverb tube.
Work done.
New filter caps, all bad resistors and a couple that were wrong according to the schematic and caps replaced, for lack of a better name the death cap removed, 3 wire cord added and all new tubes.
Amp sounds good now nice and quite, tem works well even reverb is working but it may still have output issue. With the volume all the way up and playing through it, it is not all that loud. When checking the output of the amp it comes out to 12.5 watts. Would that be correct or should it be more? Haven't been able to find out what the output should be.
Work done.
