I learning tube amp troubleshooting and maintenance. I am checking bias or first time in my EL84 push pull amp. While checking resistance on my 20W center tapped output transformer. Assuming I am checking correctly, by measuring from B+ to pin 7 on each tube (blue wire and then brown wire). My readings I come up with are:
V6 Resistance = 71.9 Ohms
V7 Resistance = 58.0 Ohms
Question 1: Did I measure resistance at the correct points
This amp is currently biased
V6 = 23.6mA
V7 = 18.9mA
I would have thought the two sides of the transformer would have ohmed out a lot closer to each other.
Question #2: Is this indicative of a potentially unmatched set of power tubes?
Thanks
V6 = 23.6mA
V7 = 18.9mA
Thanks
