I just acquired a XXX head for stupid cheap. It wouldn’t power on but the ht fuse was shot. I changed it and installed new tubes. No it powers on but doesn’t produce any output. My meter crapped out on me so I’m kinda stalled out till tomorrow. I just thought I would reach out to the gurus on this forum for advice. There is nothing obvious like burnt components. I replaced all the fuses. Thanks in advance.
Peavey XXX powers on but no sound
Hey I bought a (not stupid) cheap XXX that was similarly quiet recently! Two of the 100 Ohm screen grid resistors was burned, check them for continuity (with everything unplugged and no tubes).
They are at least on a removable board and don't require drilling out rivets like on 5150 etc.
I always replace them with 750-1k 5W versions, lately this type
Ohmite 45F1K0E, 1k 5W, wirewound rated to 460V/275C, 1%, $1.73 at Mouser, I mount the up off the board to give them a chance to cool a little better
(CR100/103 can also benefit from some space from the board as they can burn a hole clear through when they go)
Good luck! If its not the SGR be sure the tubes are good, then we can run down voltages...
Once you have a meter!Last edited by tedmich; 01-26-2020, 10:47 PM.
Just a note: on 5150 et al, I don't bother drilling out the rivets. I can measure those resistors from the solder side. ANy need replacing I just unsolder them and poke their wires on through the board. The part falls into the chassis where I can easily fish it out. I then mount the new part up on the solder side, all exposed and accessible. the amp doesn't care.Education is what you're left with after you have forgotten what you have learned.
- Likes 1
Amp makes no sound?
Are ALL the heaters lit?
Is there B+ voltage on both pins 3 and 4 of each power tube socket? And is there good bias voltage on the pins 5? (I don't know, maybe -45 to -60v)Education is what you're left with after you have forgotten what you have learned.
Are the tubes not red-plating with no bias voltage? You did not say whether you found B+ or not.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Update: I shelved this amp for a bit but decided to dive back in to it. I found that R64 was fried and replaced it with a ceramic equivalent. When taking the amp out of standby it split that resistor in half! Exciting!!!! I’m definitely getting closer.
SOmething is shorting out your SCREEN node B+, most likely a tube, but also possible filter cap. Beyond that we have actual shorts between traces, solder blobs, that sort of thing.Education is what you're left with after you have forgotten what you have learned.
- Likes 2
