What resistance do you measure from the rectifier output to ground?
Marshall Superbass with mystery short in power supply. Exorcist required.
Originally posted by christarak View PostI think by removing the HT fuse, I have eliminated all the tube sockets. Everything from V1 to OT. The short is happening with no HT fuse AND with the Standby Switch closed. Standby switch open shows no short. Filament and bias supplies (replaced 2 leaky caps and its diode) are On with Power ON, and don't cause any issues.
Anything else you can think of Glebert, or can suggest I check? I have a couple of other suggestions to check on when I get back to my workshop.
So the standby switch is before the rectifier on this? That seems weird. You mentioned bringing it up on a variac with standby ON. Does the HV come up at all when you do this or is it basically 0v?
Well, you could pull the rectifier that you just put in and see what that does and just step it back towards the standby switch.
Originally posted by christarak View PostI think you've confused me, xtian. With 2 tubes out and the same speaker load do you use half or double the output tap? I thought it was half. . if I understand you correctly, if he had an 16 ohm speaker he would need to use a 32ohm (non-existant) tap, and not the 8ohm tap that I thought.
Originally posted by xtian View PostI am, in fact, confused. I thought if four tubes are happy pushing against X impedance, two tubes would be happy with X/2 impedance. Is that not correct?
The impedance thing is an important and worthwhile discussion, but mismatching speaker to transformer here is not going to short out the B+ or blow fuses.Education is what you're left with after you have forgotten what you have learned.
Originally posted by The Dude View PostWhat resistance do you measure from the rectifier output to ground?
So I thought "bugger it. I'll put two 220K totem resistors across the capacitors". Same. Short circuit appears when closing the Standby switch.
I'm stumped Dude.
Originally posted by christarak View PostThanks for that idea, doombass. It must be something weird like that. I'll check that when I get home in 5 hours and report back.
Originally posted by g1 View PostNothing has been accidentally grounded at the center of the totem-pole filter caps? (cap shells insulated if required)
Originally posted by christarak View PostI am knocked out by the suggestions. After a whole bunch of tests recommended by our colleagues, I seem to be coming back to my brand new F&T 50+50uF caps. I'm not sure what you mean by cap shell insulation...but its starting to sound good. The resistance to the HT/B+ side of the totem cap to ground was 74K. The resistance from the centre of the totems to ground was 1M.
In my case what pointed me to the first filter cap being shorted was the big carbon resistor coming right off the Rectifier and just before the first filter cap. It started cooking and crackling even at reduced voltage with a variac, and with no other tubes in the amp. I replaced the can cap with conventional single caps and all was then well.
Hope this is your issue and g1 got it. I'm in this game of fixing my own amps only for close to three years now, and already I've gotten two bad JJ tubes and one bad cap, supposed to be brand new !
For more information read to quote at the bottom of my post..." Things change, not always for the better. " - Leo_Gnardo
Well there's just not that much to inspect and the usual method of discovery hasn't been explored for some reason. Just start disconnecting things one at a time until the problem stops. When the problem stops you have found the culprit. I would disconnect things as shown below. A possible exception being a miswire that could have existed before you got the amp. It was reported that it kept blowing fuses and the fuse holder needed to be replaced.?. That seems like an odd order of thinking. If a lamp keeps blowing light bulbs I typically wouldn't suspect the socket.
Last edited by Chuck H; 01-28-2020, 02:08 PM."Take two placebos, works twice as well." Enzo
Just a thought. The stacked caps are wired in series watching polarity. In other words negative of one cap to positive of the other. The generic dual 50+50 cap has them in parallel, not series. So both negative sides are wired together. There is no way to wire a single dual 50+50 cap for series. Could this be something we did here?Education is what you're left with after you have forgotten what you have learned.
