I am in the weeds with this one. Neither preamp tube lights. Heater supply fuse FS4 blows instantly with no tubes in at all. Lookong around for shorts, I find TR1 with 2.5 ohms across E to C in circuit, so I pull it and it measures the same. Fired it up with a fresh fuse and no tubes, and it still blows.
I don't really understand what is going on here with all these transistors.
Another thing I notice is charring under the board next to TR7 and another trace that goes to the Hi/Lo power switch. BD647 comes up as a NPN silicon darlington, designed to be used in a pair. I don't see what it's function is here.
I could sure use some help with sorting this one out.
http://schems.com/bmampscom/trace_el...locette12r.pdf.
