At first - I want to THANK YOU all of you that helped me over the last months with old Ampegs. I've been collecting then I learned so much from you, reading and reading and reading...! Few days ago I did the most complicated repair job on my '62 B15N. The amp came to me with bad power transofmer (already non original and dead/shorted), leaked caps, sloppy wiring, non functional standby switch. etc... I have installed new PT which is exactly up to specs with original one, set new caps (along with bias 50uf bias cap and 270ohm resistor), new 1k 10W resistor too. I cut the thermistor (it didn't look right and measured strange...), cut the death cap and made a ground point along with 3-prong cable.
THAT moment when you first hit "Power" and after that, the "Stanbdy" - the heartbeat and you know... The thing wasn't powered since 1970s. The amp actually turned on and its working, super quiet, God, it all went OK. What I don't understand - and of course try to read and learn but it all is too technical - the difference between cathode biased amps and fixed bias amps. In fixed bias ampegs I try to change the bias resistor to make it around 60-70% dissipation. But in cathode biased amp they are all "self-biasing", right?.. You put a set of EL84 in your AC30 and don't even look on the board... that what I remembered.
So I checked the bias in Ampeg and it's near 70mA per tube. Isn't it a bit high? Cathode resistor is 270 ohm, VDC across the resistor 35V and 50uf bias cap and 450 PV. I noted that when I chaged the 6L6GC sets, the bias changed as well +/- 10mA per tube (as with fixed bias amps), so it's not that plug-and-play as I thought (mind the stupid question...). I know that changing the catjhode resistor will result in bias change. So really similar to fixed bias amps?
Is there any "safe" correlation between plate voltage and bias amperes like in fixed bias amps? I have checked my other '61 B15: 250 ohm CR, voltage across it =30V, 100uf cap and 425 plate voltage. Tubes is that particular amp draws like 60mA/pc. Should I worry with 70mA/tube in cathode biased amp in the '62?
