Bugera 6260 issue
  • #31
    A reading taken right at the winding both loaded and unloaded would help.
    As well as confirmation of a good battery and/or meter calibration. And still... Maybe this is normal for this amp.?.
    This is really just something I'd want to be cozy on before buttoning it up. But it's not my matter.
    And probably best to just do the direct board solder as suggested by the manufacturer. But still, confirm voltages.
    • #32
      And we are getting "ther is 5v on the heater" or similar statement. What we are not hearing is 5v with respect to what?
      • #33
        If I ever see a brown spot on a molex socket used for a heater connection I hardwire the two wires. End of story. No need to measure anything.
        • #34
          Thanks for all the thoughts, gentlemen. To clarify a few pounts in the discussion, at the winding, unloaded, I was getting 6.3v. On the thick board traces on the power amp board I would get high 5v rage (can't remember exact, would rise as tubes heated). The sanding I did was on the Molex connector pin and the 6.3v winding. I put it back together before the direct solder recommendation was posted. I will communicated that to the amps owner, however.
          Since I have had the amp apart and fiddled around with it I might just buy it from him anyway. I feel bad about the whole thing. Big lesson is dont borrow anything that you are not willing to buy.
          My son is back to jamming on it now, so that is the good news.
          Thanks again
          • #35
            No reason to feel bad, Brian. No misuse involved.The heater problem would have shown anyway.
            As it is unloaded, the voltage seems somewhat low. But I am sure it was always like this. What is your measured mains voltage?
            Any contact resistance of the fuse holder and the connector will reduce heater voltage on its way to the tubes. You can measure the voltage drop across the fuse holder and connector. Tubes typically work fine if heater voltage is within 6.3V +/-10%. So something like 5.7V won't be a problem at all.
            • #36
              Agree. Brian, if anything, you saved him the cost of the repair. Like DrGonz mentioned in post #27, there was a service bulletin about this issue.
              • #37
                Thanks guys
                • #38
                  Originally posted by DrGonz78 View Post
                  I remember working on a 6262 where the yellow filament wiring had to be soldered directly to the board due to the fact that the molex connector was not holding up well. Not sure what the connector looks like in this 6260 amp but the OP keeps mentioning it looking burned and cleaning pins got it working again. But how long will those pins hold up if that is the type of connector on the amp. I think we need a picture to confirm what we are dealing with...
                  I have a Bugera 333XL....I had a problem with that molex connector.... as soon as I hard soldered it to the board, no more problems....
                  • #39
                    That was a factory service bulletin from almost the very start. In fact they wanted us to do it even to units out of warranty as a warranty repair.
                    Any Bugera amps you have/see, hard wire the transformer wire molex.
