The schematic calls for 491v on the OT center tap. I am only getting 440v in this amp. The current is only 20ma so it's not low voltage because of the power tubes drawing tons of current. Rectifier is a 5AR4. Brand new pair of JJ 6L6 installed.
Is there a different schematic for the LTD version?
I was curious if the schematic is accurate on that voltage spec or if anyone has any feedback on whether this is normal plate voltage or not. I discovered this because I felt the amp was distorting rather early and didn't have much clean headroom. Maybe it's normal, this is a desirable effect for a tweed amp.
https://www.thetubestore.com/lib/the...-Schematic.pdf
