Something I haven't yet done but often consider it is attenuating the buffered output of the Fender reverb tank (4AB3C1B), which one rarely has turned up more than a few numbers on the Reverb control (surf bands not accounted for). At the moment, I have a Fender Vibrolux Reverb combo amp in the shop, which howls quite well if you turn the Reverb level up. I first thought maybe I'd just increase the cathode resistor of V4A, presently 1.5k with 100k plate resistor. Then, looking at the schematic of a Fender Twin Reverb, I see they broke up the mixing resistor following the wiper of the Reverb pot in two sections....82k (R74) & 390k (R30), with a shunt to ground following R30 of 220k (R31). The Vibrolux Reverb doesn't have that
shunt resistor, though one could tack-solder it in between the 82k and the 390k, as the circuit is slightly different in that mixing area.
I've already pulled the tank out of the vinyl pouch, added a foam damping pad between the open pan and the cardboard one usually finds covering the open pan, though that made no difference. Just too much return circuit gain to deal with if the pot is turned up.
Custom_Vibrolux_Reverb_schematic.pdf
65_Twin_Reverb_SvcMan.pdf
