I have found out that the RED and BLUE wires on the primary side of the output transformer are switched, according to the schematics RED should go to the plates of V7 and V8 in reality it is going to V9 and V10. Same thing with the BLUE wire instead of going to V9 and V10 as per schematics, it is actually going to V7 and V8. Does this matter, should I correct this? I think I have read long time ago that this can cause weird sounds to appear??? The amp is Laney VH100R. The schematics is attached.
OT primary side reversed wires
If the wires were wrong, the amp would be oscillating because you'd have positive instead of negative feedback. If the amp has been working all this time, it's extremely unlikely it's wired wrong, unless someone replaced the transformer, wired it wrong, and you have an oscillation problem. If it's not broke, don't fix it."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
I've had factory OEM replacement tranformers be "wrong". For that reason, when I replace an OT, I don't trim the wires until I verify that it's wired correctly. You'll often find primary wires color coded differently/phasing opposite of what it should be."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
The only way to 'know' is to break the feedback loop. (R58 and the Resonance switch in the open position)
If the signal increases, then the wiring is correct.Last edited by Jazz P Bass; 02-19-2020, 03:20 PM.
Originally posted by g1 View PostI would guess you may find the grid connections (P26 and P28) reversed as well.
Anyway I just looked up photos of open Laney's on the internet, and noticed they all look like this one, so the factory simply does not respect the schematics color code..Last edited by Emetal; 02-20-2020, 12:09 AM.
Originally posted by Emetal View PostNope, those are like on the schematics, P26 is going to V7 and V8 and P28 is connected to V9 and V10
Anyway I just looked up photos of open Laney's on the internet, and noticed they all look like this one, so the factory simply does not respect the schematics color code.."Take two placebos, works twice as well." Enzo
Or, as often happens, the engineers/designers drew the schematic based on parts they used to build and design the amp. Then, the bean counters found a cheaper source for the transformer for production models and the wire colors were different from that vendor."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
