I have a YBA-1 on the bench (a later '74-ish model), with a brand new Hammond OT (the one they make as a YBA-1 replacement). The amp has an oddly distorted output (see attached). The signal on both input grids looks clean, and I tried replacing the output tubes with no change. I carefully checked the socket solder joints, everything looks OK. Any suggestions?
At low levels, it looks clipped on the positive side, at the signal gets hotter, the 'divot' in the top of the waveform gets deeper.
The voltages on all pins look normal.
