Bugera 333XL Infinium Issue
  • #31
    Hold on. It's a year since the last post. How long have those new EL34's been in there?
    There are a ribbon cables that go from the power board to the bias controller. Any poor connections on that can cause havoc.
    Here is a schematic of the tube board and bias PCB I drew up some time ago. There may be errors or be incomplete as I ran out of time to check it. Maybe it will help a little.
    Infinium.pdf
    PS: This schematic is from a Bugera 6262. I think 333XL is similar, if not the same in this regard.
    • #32
      Still like to know the exact fuses you are using, and if they have all been the same type.
      • #33
        I don't know anything about the Bugera automatic bias circuit but in a G20 that rejected the operation with new tubes I found an open resistor and an inflated capacitor. Replacing them worked again.
        • #34
          Oh that's my bad g1, I didn't see your posting. I've been using 2A slow burns that I got from tubesandmore.com. I'm not sure if they're branded but they are in fact the same fuses I've been using throughout the diagnosis.
          • #35
            One EL34 alone takes 1.5A current draw on the filament supply. If your power supply is the same as in the above provided schematics you are supposed to fit a 10A fuse. A 2 A fuse can withstand supplying the PI tube and one power tube but that's about it.
            • #36
              There's a 2AT fuse in the HT supply. I expect it's that one. A 2A fuse would never work in the heater supply.
              • #37
                This is my point. It's not working. Unless a bunch of tubes are pulled, then it works til there's more than 2A draw on the heater line again, then it blows.
                In post #6 he specified that it was F4 that blew. If he were now talking about a different one, I think he would have mentioned it.
                F4, at least in the non-Infinium needs to be a 10A fuse (fast specified).
                I guess we need to verify that F4 in the Infinium is the heater fuse.
                (edit: re-reading all the OP's posts, it's obvious we are talking about the heater fuse. Needs to be replaced with proper value)
                • #38
                  I was in contact awhile back with Bugera tech support about the fuses. "Thanks for contacting us!
                  Fuse F1-F4 are all 2 amp slow blow fuses. "
                  That's the only reason I was using a 2A fuse in F4 to begin with, not that I would know of a proper value without the schematic. Did I just get bad information?
                  • #39
                    From available knowledge and without a schematic, yes...... you got bad information. The filament fuse should be 10A as g1 said.
                    • #40
                      Here is a crop of the 333XL power supply.
                      F4 is stated as 10A Fast Blo.
Name:	Bugera 333XL.GIF
                      • #41
                        Was not the original fuse marked? Was it missing? I'm not sure why you wouldn't just look at the fuse that was in the unit and use an appropriate replacement?
                        • #42
                          The fuse that was in it when I got it from a friend was a 2A. He was getting the no sound and check tube LEDs. Obviously he must've changed the F4 fuse with an incorrect replacement. I don't know what caused any of the issues to begin with, or if he just somehow blew the fuse and put the wrong value in. I contacted Bugera and asked about the fuses when I kept popping the 2As for what seemed like no reason. They told me 2A for all 4 fuses (thanks a lot), so I also used 2As. For all I know I'm no closer to determining what the original issue even was.
                          • #43
                            It's always more "fun" when a user tries to fix an amp himself.
                            In this case, I'd have a close look at all of the other fuses and make sure they are the correct value. You never know- there could be a 10A fuse in a place where there's supposed to be a 2A fuse. Somebody may have mixed them up.
                            • #44
                              Yeah that idea had already dawned on me. I'll have to check that out in the afternoon. Would the Infinium version have the same fuses as the non-Infinium, because that schematic piece of the power section is definitely showing 2 other fuses as 1As? Could the Bugera contact have been *that* wrong? (don't answer that)
                              • #45
                                F1: 2A FB: High voltage supply.
                                F2 & F3: 1A SB: Dc heater supply.
                                F4; 10A FB: main AC heater supply.
                                All values seem reasonable.
                                Bugera was pulling your chain.
