MEF Members -
To learn a bit more about Class D amplification, I bought a kit from ebay - LJM L15D KIT IRS2092 Power amplifier kit (with IRFB4019 MosFets). For a tad over $20, it was an interesting build. But without a schematic, it kinda defeated the point. Eventually, I did find a schematic for this board - directly from International Rectifier. The schematic is a match. The only thing that is tricky is understanding the Overload Protect and circuitry around the relay. I do not see the relay per se - I do see the "open" note next to R29A and C9A. I also see a couple Diodes on the schematic D5A and D6A near the output. I believe those are created by combining two 2N5551 transistors connected to one another in an odd way. Anyway, I am working through all that. The amp is working - yeah!!
So, my question centers on the ripple (or oscillation) that I am seeing on the Power Supply. I am using my Peavey 400BH Module Power Supply Project for the plus and minus 50 volts. The ripple (unloaded) looks like one would expect - the typical sawtooth shape. But when I connect the power to the amp board, I am seeing something totally different. It is hard to measure the amplitude and try to discern the frequency. Is this normal? I am wondering if the 2092 chip is causing this.
The amp sounds clean - I am just curious about the waveform on B= and B-.
Thanks, Tom
Thanks, Tom
