(sorry, just a non-expert guess) loose (something changed so possibly a nut loosened over time) RV 10 (A250k) pot body becoming a significant impedance over which RF is C coupling into the feedback loop?
Sessionette - highly sensitive to EMI
Originally posted by Helmholtz View PostIs C44 good (low ESR)? Wondering why only grounding its negative end stops the noise.
Mick removed and bypassed that cap in the first post so it can't be that.
I see the focus in on the signal path but I wonder if the noise is getting in the ground side of things. If that is the case then I would expect the noise to come and go dependent on where you ground the negative end of C44 to. That process might lead you to a point in the ground path that had gone high impedance, at least at high frequencies.Experience is something you get, just after you really needed it.
I see the focus in on the signal path but I wonder if the noise is getting in the ground side of things. If that is the case then I would expect the noise to come and go dependent on where you ground the negative end of C44 to. That process might lead you to a point in the ground path that had gone high impedance, at least at high frequencies.- Own Opinions Only -
Originally posted by Mick Bailey View PostThe pots ground fine. With IC6 removed and pin 1 grounded the noise is still there, so the problem is after this. I've had to park it to get some other repairs done, but it still doesn't make sense to me.
Originally posted by nickb View PostMick removed and bypassed that cap in the first post so it can't be that.
(sorry for the interruption, carry on...)
Further investigation shows noise is also getting picked up by the screen of the reverb cables. With my original phones used for testing I though this was a problem fixed and there was insufficient screening, but not so with the new test phone. I think nickb has identified something I'd overlooked.
This reminds me very much of noise on a digital ignition system I designed where I thought noise was propogated by a switching IGBT. It took me months to identify the noise was the ground reference being pulled up - something called 'ground bounce'. Because my scope was always referenced to ground I was always looking at what the probe was seeing relative to ground. Time for a different approach.
Changing the cap for low ESR made no difference, neither did a tantalum.
