Ok if I recap a 8uf bias cap with 47uf ? (Traynor YGM-3)
    Originally posted by nickb View Post
    At this point the OP is probably banging his head on the workbench wondering what he did to cause all this. I liked my original answer. "It'll be fine"
    Originally posted by Helmholtz
    To the OP the difference is an estimated 15s or a simulated 10s bias ramp up.
    That's what I thought at first, without any math. Just make sure you let the amp warm up sufficiently before switching standby to 'GO' mode, and all will be well. Plus a reduction in background hum which is often a bugaboo with lightly filtered bias supplies.
      I found PSUD2 to be a convenient tool to simulate the bias ramp up. As expected I could fully confirm nickb's results.
      (Also gave me reason to read up on Thevenin equivalents. Thanks again, Nick!)
        How many extra seconds for the 47uF compared to the 8uF? I think I'm mis-reading post #15.
          See post #12 for the answer. It depends on what you define as the measurement point 90% of final value, or 10% to 90%, or.... There's a graph so you can chose your points.
          PS: The executive summary is that after 10 seconds they are pretty much the same.
            From Nick's simulation in post #12 (green curves) it looks as if it takes less than twice as long with the 47µ to reach an intermediate voltage value as compared to 8µ.
            E.g. -20V is reached after 5s with 8µ and after 9s with 47µ.
              Got it. Thanks guys.
