Note the most recent drawing shows a 10 ohm resistor.
Acoustic 370 turn on thump
This problem is more complicated than I initially thought. The easiest solution is to live with the 10 second wait time.
A surge thermister would slow the rise of the power supply which should prevent thumping. see msg #17
Years ago I fixed an amp with a surge thermister. I don't remember the brand, not a major brand but not unknown either, anyway the
problem turned out to be the thermister itself burnt out so maybe it would have its own set of problems
Originally posted by dmeek View PostThis problem is more complicated than I initially thought. The easiest solution is to live with the 10 second wait time.
problem turned out to be the thermister itself burnt out so maybe it would have its own set of problemsThis isn't the future I signed up for.
Originally posted by Helmholtz View PostWell, a 10R resistor will have to dissipate 100 times the power of a 1000R resistor (when connected to the same voltage).This isn't the future I signed up for.
I converted the ground switch to the standby switch using a 470 ohm 5 watt resistor. I pulled the ground cap and installed the resistor on the terminal strip it occupied. One of the wires was already there, so it was pretty easy. It works like a charm! I will install a new output cap when it arrives, and this customer will be happy.
Thanks as always!It's weird, because it WAS working fine.....
