Yellow dust in 70s Twin Reverb
  • Yellow dust in 70s Twin Reverb
    A customer brought in an older Fender Twin Reverb for repair. Complaint is blows fuses. When I was removing the chassis from the cabinet, I noticed this yellow dust all over the tubes and tube covers and the chasis and transformers. This stuff is nasty and burns the eyes and nose. I thought fist of a blowed up cap, but the dust was not under the cover for the filter and high voltage caps. All the other caps appear visually ok , but I have not tested all of them yet. Any ideas what this stuff is and where did it come from? Is it related to the fuse blowing? The fuse blows a few minutes after the standby switch is thown and a low level signal is sent to the input.
    Thanks for your responses
    ToddRV
    Can't imagine it is involvd in teh amp problems.
    That stuff is common, it is the metal finish on teh chassis breaking down over time. If I am not mistaken the finish is galvanized and this crap is zinc oxide. In my experience it doesn't cause trouble other than hurting your eyes if you rub them.
