Hi,
I've got a Roland cube 60 cosm that is only working through the headphones.
It was acting strange for a while before it stopped working through the speaker. When I turned the amp on sound would only come through if I turned the volume up quite a bit and then it would suddenly kick in.
I've cleaned the input socket and headphone socket with contact cleaner and that didn't help. I then desoldered the headphone socket from the pcb to double check it wasn't muting the cab in some way but that didn't help either. Also I've run the speaker through another amp so that's working ok.
Any ideas on what could be causing the speaker not to work?
Thanks,
Pete
Thanks,
Pete
