This amp works on the 'L amp/out high' side, but there is no sound on the other side 'R amp/out low'.
There's no DC on the R out and there appears to be no shorted transistors. All resistors are measuring the same as the good side. The only sign of heat is one resistor R78 on the the front or pre amp board. This resistor is the only one that has taken too much heat. It looked to me to be a 1k 1/4 watt carbon film resistor that was still measuring 1K. I changed it out with a new one. Although the schematic says it's a different value, I put in a 1K. I'm not convinced the schematic I attached is exactly what Im working on here. But changing that resistor did nothing anyway. Does anyone know of a better schematic?
I swapped out U9 which did nothing. U10 is, I think, labeled LU1 and RU1. I attached a photo of the area showing LU1 and R78. As you can see there are a lot of components listed with right and left designations.
There's nothing like that on my posted schematic.
Also, when depressing the 'bridged mono in/on' button, it has no sound out of either side. I'm hoping there is some kind of switching problem. I'm not sure how to proceed from here.
Oh, voltages... There's 80v +/- going to both modules, and for low voltage there's 14v on the L side but 11v on the R side. I wonder why this is happening.
Can anyone help me with this, I'm stumped?
