Hi
I have a TSL601 which I’ve had for at least 17 years, It’s been running fine until yesterday when I got crackling on the speaker while playing, it seems to go and I continued my playing session.
Today, I’ve turned on the amp and there is no sound at all on any of the channels.
What I know
-User replaceable Fuses are all ok
-Standby light is on
-All Tubes are lit
-When I switch the standby button there is the same slight crackling in the speaker I heard yesterday, But only every now and again.
-On the lead channel with no instrument plugged in I get a high pitched squeal. With instrument plugged in this doesn’t happen, other 2 channels are silent apart from random crackle.
-the fx return is also silent.
Valves have been in the amp since around 2006ish they are J/J E34L power valves, original Marshall pre-amp valve.....this amp is only very occasionally used. In the 17 years I’ve had it I say it’s had about 4 years of playing, used quite a lot when I got it no so much these days.
I have opened the amp just to have a quick look to see if there was anything obvious, there are two samwha 315v 330uf caps that appear to have domed tops but I’m not sure if this is just the plastic Coating on top Of the cap, if I push on it it returns flat. There was nothing obvious, no smells.
Would like to know if anyone here could narrow this problem down from their experience before I decide where to spend pennies......I’m hoping it be valves. I have had this amp die before not long after I got it which is why it has the JJ valves in but that was just dead, this time its still alive but has no output.
Thanks
Steve
Ps, I have basic multimeter skills so don’t go to tech on me...
What I know
-All Tubes are lit
Thanks
Steve
