Can someone help me with next steps here?
bought this "amazing build" but it was redplating
So i'm reading that this is a common issue with this model? Crazy voltages and redplating, now slightttt (have to go to a dark room) but still there. The transformer should be spec'd correctly based on the layout showing the 290 for primary, i'm getting like 300 there , so not really sure why everything is so high. Model used here is PT -290-50 HT-6179-50
So far i've upped the sag resistor from 22 ohm to 34 ohm, the bias resistor is now at 165 ohms
DCV Pins with Tubes giving the same readings
1 N/A
2 V1 - 26mv, v2 33mv
3 14.18V
4 .2mv
5 0
6 N/A
7 375v
8 N/A
9 382v
If i go up to like 210 ohms for the bias resistor, will that kill the plate voltages?
whats next steps here?
love the sound of the circuit, seems like im close here but worried about upping the b+?
1 N/A
3 14.18V
4 .2mv
5 0
6 N/A
7 375v
8 N/A
9 382v
