Hello,
I have another Crate VC50 amp on the repair bench. This time its the VC50H
Head amp, rather than the combo model with 3 cabinet speaker. The “A” (clean) channel is working, but have virtually a completely dead “B” (dirty) channel. I checked the continuity of the push switch for changing channels and this switch seems like it doing its job. All tubes test fine. I checked the footswitch jack for proper switch closing, and it is fine. Trying to wrap my head around how the switching is accomplished. It appears to be by the toggling of a +10v to 0v on one line and -10 to 0v on another line. Should I be checking the -10V +10V power supply section off main PT separate winding, or could the Vactrol “like a optoisolator”, but light dependent resistor instead of photo transistor be defective? It appears the no 4 Vactrol might be used in the channel A/B switching, as well as the -10/+10v supply “if I understand correctly?” Any suggestions of where I should be looking for a defect in the circuit?
If not, could someone please break down the channel A/B switching method down into plain english for my understanding.
Thank you
Schematic found here: https://drive.google.com/file/d/1V1M4gZApJuNIbGpUFbJfuBiAL1BCHRp7/view?usp=drivesdk
Thank you
