Had an Ashdown 515 in the junk pile. No output. Running TIP 142/147 pair for output. One was dead, other had leakage. I removed and looked at the OC voltages on the pads ( emitters appx 46v bases millivolts, collector 2 and 6 volts ground ref). I had a tip142/147 T pair just to try. Lower power rating. The amp worked for 5 seconds then both sizzled. The pots may have been maxed. Did they burn because of the power rating or a bias issue?
Does anyone have a schematic? Thanks
