Hey there,
I have a Peavey Classic 30 that is emitting a faint but noticeable mechanical buzz. It appears it's coming from the filter caps, which in this amp are 6 10UF@450 caps.
Video here: https://imgur.com/a/vU1SzcT
Should I suspect a bad cap?
All voltages are spot on. Amp sounds really good. Operating well with no strange noises or buzzing in the output.
The amp came to me with a broken power transformer (FYI, it wasn't the thermal fuse). I've just installed a new PT.
Classic 30 schematic attached here is not an exact match to this amp, but should be close enough. This one is one of the newer models with Standby switch. If anyone has the correct schematic, I would love a copy.
