Please help! this amp has me stumped.
this is like the Sunday afternoon puzzlers Charles from swamp amps used to post.....the only problem is I don't know the answer, yet.
Here's the back story.
I am able to get it to bias up (-60V) and it behaves fine with a single note signal. As soon as I strum the bias drops out and goes positive until the power tubes redplate.
The B+ is about 540V. The filter caps are original. It is an early V4 with the single 100mfd cap in the bias circuit.
I have replaced the bias feed cap (ac divider), diode and filter cap. The resistors tested fine.
I replaced the diode on the standby switch.
I have replaced the PI 12AU7. I have replaced the coupling caps (tropical fish at .47mfd) with .33mfd nos mylars.
The power tubes are 2 weeks old. sovtek coin base 6l6WGC's. they test OK on my Hickok.
I tried deriving the bias supply from the AC windings rather than a capacitance divider and the bias simply collapsed to positive a little faster.
I'm open to any and all suggestions....
Thanks,
Marc
Thanks,
Marc
