I have an Miyuki ELK ES30 amp from 70s Japan armed to the teeth with 12AX7s and EL84s. The previous owner had it serviced and the volume pot was changed. The shaft isn't the same length and pushes the knob forward in a slanted angle.
I was going to replace it, but then i noticed it was written B100K Ohm on the back of the pot (linear taper?). Most amps have 1M volume pots, so why 100K? Also using a ohmmeter, i can read 73K. So it's either of very bad quality or another component is acting in parallel.
This amp is very rare and couldn't find schematics anywhere. The only one i found was for their Twin Amp 50 model which has 1M volume pots.
Should I go with a 100K or 1M pot to replace it? Other than this cosmetic issue, the amp sounds surprisingly fine. Would it benefit from a higher value pot?
Thanks for the help and knowledge.
Do
Do
