Just finished a 5e3x2 build from Ted weber. It seemed to work fine at the shop, just a touch noisy and hard to control the volume (normal for a 5e3) I brought it home, and decided to make a couple of minor changes. added some more filtering (extra 40 uf cap after the rectifier (which is tube)) and a .22 mallory in the first stage (As on Steve A's blues express plus 8Ha)
I also added a resistor network from the volume controls to the tube stage in an attempt to make the volumes a little bit less interactive.
IT seemed to work fine... the controls were still interactive but a little less so, then i heard a squeal start, turned around and saw the Rectifier pop (flash brightly and go out) and then all 4 power tubes in quick succession... i hit the power and have left it to cool down. Any ideas of what it could be? I have a few suspicions....
-Parasitic oscilation got stronger until i could hear it and it could do dammage.
- too big a filter cap after the rectifier (the weber SS rect was defective so i was using Tube)
Any other ideas???
Any other ideas???
