Johnson JT50 Mirage Amplifier HELP!!
  • Johnson JT50 Mirage Amplifier HELP!!
    Hello,
    I have recently made the choice of owning a Johnson JT50 Mirage Amp over a Fender Stage 1600 because of it's variety in amp types and sounds that it can make. However, the Johnson amp is kind of an old amp, and because of this, it doesn't seem to be functioning right. Here are the difficulties:
    -When the amp is turned on, you can not choose which bank/preset you want.
    -When the amp is turned on, SOMETIMES it generates a sound
    -When the amp DOES generate a sound you still can not choose which bank/preset you want via on the amp.
    -When the amp DOES generate a sound and you select an amp model type, you have to turn a tone dial (treble, mid, bass) in order for the amplifier to change the model type
    -The pedal SOMETIMES works when the amplifier is turned on
    I have checked the fuses and neither of them are broken. Any feedback/thoughts would be GREATLY appreciated.
    Thanks a lot!
    Nick
    Have you tried a factory reset? Also it could be that all the controls and jacks need to be cleaned.
