Lafayette Bass Head late 60's
In this schematic, plate voltages are listed. When I take plate voltage readings from the pins. Should the readings I get be within 10% of what is listed in the schematic? Where should I look if the plate voltage measurements are much higher then what is listed on the schematic?
specifically I'm referring to the 12ax7 and the two 12au7's
thank you,
Gary
