I've got a Marshall JCM TSL on my bench. The customer complained that the
output volume was low.
He had gone ahead and purchased a complete set of pre and power amp tubes.
On my bench the output is very low, and the distortion channels don't have much gain. I went ahead and swapped in all his new preamp tubes. This
gave no improvement. I plugged straight into the effect return and got a fairly
strong signal.
I figure the problem in somewhere in the preamp and at a node that is shared by each of the channels.
Found the schematics at Dr. Tubes site. Yikes. It's a bit hard to trace the signal since you can't see the entire signal path on one page with all the connectors. I'll go ahead and do that...
But first, anything that you Marshall experts think I should be looking at?
strong signal.
