This is my first post on here so a big hello to all
I have a jcm900 dual reverb 100W combo which was fine until the volume started fading out and then finally it gave up the ghost.
I've taken the chassis out and inspected and continuity tested the fuses and all is well there but Ive noticed that R30 which connects to the full/half power selector switch and one leg of a smoothing cap has burnt out (22k/1W?)
Do any of you learned people know what may have caused this?
I will be fitting new tubes soon when watford valves re opens after Christmas so could it have been a dodgy valve which caused the burnt resistor?
The amp is usually run at half power.
thanks in advance for any light you can shed on this problem.
Gaz
Gaz
