Ive an old EL34 based tube amp, and I noticed a consistent orange wire running from the grids(pin 4) and the heaters(pin 7) of the power tubes to all of the heaters(pin 9) of the six 12AX7's. I suppose this is how the filaments are heated up?
Understanding the heating of a 12AX7
Also, another conistent wire I noticed following a similar pattern. A brown wire coming the heater(pin 2) of both power tubes is going to every heater(pin 4) of each 12AX7. Meant to point out that the orange wire previously mentioned is going to each heater center-tap(pins 9). Anybody know just what the wires are acheiving?
I have to doubt that the same orange wire connects pin 4 of the power tubes and any heater connection.
Pin 4 of an EL34 is its screen grid, and screens sit at B+ voltage - several hundred volts.
Pins 2 and 7 are the heaters of the EL34 - there should be 6VAC between them. In some amps that 6VAC could also be elevated above ground be some DC voltage - but not several hundred.
In the 12AX7, pin 9 is the center tap of the dual filament heater. Pins 4 and 5 are the ends of it. COnnect 12V from pin 4 to pin 5 and the tube heater runs on 12v. But connect pins 4 and 5 together, and now the two halves are in parallel, so the tube heats with 6V. SO the same 6VAC for the power tubes could also run the preamp tubes by running to pins 9 and 4+5.
The heaters of most power tubes are run on AC 6V, but tubes can also run on DC if you want. In power tubes it doesn't matter, but in sensitive preamp tubes, making the heaters DC operated is one way to reduce hum. SO sometimes there will be separate wiring to some preamp tubes. But sounds like your amp is plain old 6VAC throughout.
Your heaters have their own 6VAC winding on the power transformer. It should be totally independent of the +400vDC on that screen grid.Education is what you're left with after you have forgotten what you have learned.
Nope, no hidden agenda here. Counting either direction, pin 4 won't be a heater, and pins 2 and 7 wirk out to be heaters either way as well.
But as anyone who ever traced out a circuit knows, when wires go into bundles or even just parallel paths, they can easily be confused.Education is what you're left with after you have forgotten what you have learned.
Enzo you are correct. There actually IS an orange wire coming off of both power tube screen grids, but its not going to pins 9 of the preamp tubes. Its going to the cap can. My apologies.
man thanks for that knowledge. Now looking at it I see 6VAC coming from the EL34 heaters going to the center taps of the 12AX7's, whereas there heaters are indeed connected and in parallel producing 6V instead of 12V. cool stuff.
Now what is the brown wire doing that the orange wire isnt, or vica versa??
Originally posted by Enzo View PostIn the 12AX7, pin 9 is the center tap of the dual filament heater. Pins 4 and 5 are the ends of it. COnnect 12V from pin 4 to pin 5 and the tube heater runs on 12v. But connect pins 4 and 5 together, and now the two halves are in parallel, so the tube heats with 6V. SO the same 6VAC for the power tubes could also run the preamp tubes by running to pins 9 and 4+5.
Originally posted by olddawg View PostEnzo, I have always wondered if you could convert an old chassis that uses 6SL7s to 12AX7s by wiring the filaments in this way. There would be a lot of other rewiring as well , but could you rebuild and old amp chassis that has only a 6v filament supply to us 12AX7 preamp tubes? I have an old mil spec rack mount 6L6 power amp that I wonder if I could add a preamp section to this way.KB
MOST guitar amps run their 12AX7s on 6v.
ANd pretty much the only time I see them on 12v is when they are wired in series over a 36v supply or a 48v one.Education is what you're left with after you have forgotten what you have learned.
