Gibson Falcon bias.
  • Gibson Falcon bias.
    Hi there!!
    I had adjust some fixed-bias amps in the last year, but last night was my first cathode-bias amp.....
    It was a Gibson Falcon. 2 6V6, GZ34, 6C4 and 3 6EU7...
    Measurements are done using this information, http://www.diyguitarist.com/GuitarAmps/PT-Biasing.htm,
    and those are my numbers...
    Cathode Current = Cathode Voltage/Cathode Resistor Value
    0,0537 = 25,8 / 480
    Screen Current = Voltage Drop across Screen Resistor/Screen Resistor Value
    0,0126= 10,5 / 833
    Plate current
    = Cathode Voltage/Cathode Resistor Value - Screen Current
    0,0411 = 25,8 / 480 - 0,0126
    Plate Dissipation in Watts
    = (Plate Voltage - Cathode Voltage) x Plate Current
    12,74 = 339 - 25,8 x 0,0411
    I had read that in cathode bias amps is safe work hotter than in fixed bias amps, but... isnīt this value too hot?
    The tubes are new TAD 6V6GTB-STR.
    Them, i install the originals RCA 6V6 and the PLATE DISSIPATION dropp to 10,80 watts. Is this in the safer range?
    Thaks everybody....
    13 watts for this amp is about right
