The original problem with this amp was that the "ECHO" would not shut completely off. I removed the echo pot, soldered in a "replacement" and touched up a few loose connections on the board.
The original 50K nylon shaft pot is no longer available through GK so I got a 16mm 50kL pot with a metal shaft. It went right in, no problem.....
but then...
I turned it on using a variac, as soon as a little bit of AC was introduced the amp started to hum. No signal was introduced at this time. I checked the original with my meter and it went from 2.5ohms smoothly to 50k. I'm going to put the original pot back in and start from scratch. Has anyone worked on one of these amps with this problem? I have no schematic....
Thank You,
Gary
but then...
Thank You,
Gary
